Vector Curves Node¶
Vector Curves Node.¶
The Vector Curves node maps an input vector components to a curve.
Use this curve node to slow things down or speed them up from the original scene.
Entradas¶
In the shader context the node also has an additional Factor property.
- Factor
Controla la cantidad de influencia que el nodo ejerce sobre el vector de salida.
- Vector
Entrada estándar del vector.
Propiedades¶
- Canal
X, Y, Z
- Curva
Para los controls de la curva vea Complemento de Curva.
Salidas¶
- Vector
Standard vector output.
