Vector Rotate Node¶
Vector Rotate Node.¶
The Vector Rotate Node provides the ability to rotate a vector around a pivot point (Center).
Inputs¶
- Vector
Vector to be rotated.
- Center
Point to rotate around.
Properties¶
- Type
- Axis Angle
Rotates the vector around an axis defined by the Axis input vector and the amount of rotation is defined by the Angle input.
- X, Y, Z Axis
Rotates the vector around the defined axis and the amount of rotation is defined by the Angle input.
- Euler
Rotates the vector about the Center and defined by the Rotation input vector to control the amount of rotation on each axis.
- Invert
Inverts the rotation angle.
Outputs¶
- Vector
The rotated vector.
