Instances to Points Node
The Instances to Points node generates points on origins of top-level instances.
Catatan
Top-level instances are those that are owned by the node's input geometry. Instances owned by other instances, i.e. nested instances, are not considered by this node.
Inputs
- Instances
Standard geometry input.
- Selection
The instances used to generate points. True values mean a point is created for the instance, false values mean the instance is skipped.
- Posisi
Overrides the default position of generated point.
- Radius
Controls the radius of the result points.
Properti
This node has no properties.
Outputs
- Points
Standard geometry output.
