Instances to Points Node
Instances to Points node.
The Instances to Points node generates points at the origins of top-level instances. Attributes on the instance domain are moved to the point cloud points.
Catatan
Top-level instances are those that are owned by the node's input geometry. Instances owned by other instances, i.e. nested instances, are not considered by this node.
Inputs
Instances
Standard geometry input.
Selection
The instances used to generate points. True values mean a point is created for the instance, false values mean the instance is skipped.
Posisi
Overrides the default position of generated point.
Radius
Controls the radius of the result points.
Properti
This node has no properties.
Outputs
Points
Standard geometry output.
