Float Compare¶
Float Compare Node.¶
The Float Compare node takes two inputs and does a math comparison between them.
Ingressi¶
- A, B
Standard float value input.
- Epsilon
This value is used as a threshold for still considering the two inputs as equal for the Equal and Not Equal operations.
Proprietà¶
- Modalità
- Less Than
True if A is smaller than B.
- Less than or Equal
True if A is smaller or equal than B.
- Greater Than
True if A is bigger than B.
- Greater than or Equal
True if A is bigger or equal than B.
- Equal
True if A and B are the same.
- Not Equal
True if A and B are different.
Output¶
- Result
Standard Boolean output.
