Map Range Node¶
Map Range Node.¶
This node converts (maps) an input value range into a destination range. By default, values outside the specified input range will be proportionally mapped as well. This node is similar to Map Value node but provides a more intuitive way to specify the desired output range.
Ingressi¶
- Valore
The input value to be remapped.
- From Min
The lower bound of the range to remap from.
- From Max
The higher bound of the range to remap from.
- To Min
The lower bound of the target range.
- To Max
The higher bound of the target range.
Proprietà¶
- Clamp
Clamps values to Min/Max of the destination range.
Uscite¶
- Valore
Standard value output.
Uso¶
One important use case is to easily map the original range of the Z-depth channel to a more usable range (i.e: 0.0 - 1.0) for use as a matte for colorization or filtering operations.
