Convex Hull Node
../../../_images/modeling_geometry-nodes_geometry_convex-hull_node.png
The Convex Hull node.
The Convex Hull node outputs a convex mesh that is enclosing all points in the input geometry.
Nota
When the node is used on a geometry with instances, the algorithm will run once per instance, resulting in many convex hull meshes in the instance geometries. The Realize Instances node can be used to get a convex hull of an entire geometry.
Importante
Volumes are not supported by this node, and attributes are not automatically transferred to the result.
Ingressi
Geometria
Standard geometry inputs.
Proprietà
This node has not properties.
Uscite
Convex Hull
Mesh that encloses all points in the input.
