Instances to Points Node
../../../_images/modeling_geometry-nodes_point_instances-to-points_node.png
The Instances to Points node.
The Instances to Points node generates points at the origins of top-level instances. Attributes on the instance domain are moved to the point cloud points.
Nota
Top-level instances are those that are owned by the node’s input geometry. Instances owned by other instances, i.e. nested instances, are not considered by this node.
Ingressi
Instances
Standard geometry input.
Selezione
The instances used to generate points. True values mean a point is created for the instance, false values mean the instance is skipped.
Posizione
Overrides the default position of generated point.
Radius
Controls the radius of the result points.
Proprietà
This node has no properties.
Uscite
Points
Standard geometry output.
