Convex Hull Node
The Convex Hull node outputs a convex mesh that is enclosing all points in the input geometry.
Nota
When the node is used on a geometry with instances, the algorithm will run once per instance, resulting in many convex hull meshes in the instance geometries. The Realize Instances node can be used to get a convex hull of an entire geometry.
Importante
Volumes are not supported by this node, and attributes are not automatically transferred to the result.
Ingressi
- Geometria
Standard geometry inputs.
Proprietà
This node has not properties.
Uscite
- Convex Hull
Mesh that encloses all points in the input.
