Blender 2.92 Manual Logo
  • 블렌더 시작하기
  • 화면(UI)
  • 편집기(editor)
  • Scenes & Objects
    • Scenes
    • Objects
      • Introduction
      • Object Types
      • Object Origin
      • Selecting
      • Editing
        • Transform
        • Mirror
        • Clear
        • Apply
        • Snap
        • Duplicate
        • Duplicate Linked
        • Join
        • Parenting Objects
        • Relations
        • Make Links
        • Shading
        • Convert To
        • Show/Hide
        • Clean Up
        • Delete
      • Properties
      • Tools
    • Collections
    • View Layers
  • 모델링
  • Sculpting & Painting
  • Grease Pencil
  • Animation & Rigging
  • 물리법칙
  • Rendering
  • 합성하기(compositing)
  • Motion Tracking & Masking
  • Video Editing
  • Files & Data System
  • 애드온(add-on)
  • 고급 기능
  • 문제 해결하기
  • 용어 사전
  • Contribute Documentation
Blender 2.92 Manual
  • Scenes & Objects »
  • Objects »
  • Editing »
  • Make Links
Make Links¶
Reference
Mode
Object Mode
Menu
Object ‣ Make Links
Hotkey
Ctrl-L
Links objects between scenes or data-blocks of the active object to all selected objects. In some case (i.e. Object Data, Modifier) the target objects must be of the same type as the active one or capable of receiving the data. If targets already have data linked to them, it will be unlinked first.
Objects to Scene
Links the selected objects into a different scene than the current one. The Link Objects to Scene in the Adjust Last Operation panel lets you choose between scenes.
This makes the same object exist in more than one scene at once, including its position and animation data. The object’s origin will change its color to reflect that.
Data-block type to link.
Object Data, Materials, Animation Data, Collection, Instance Collection, Modifiers, Fonts, Effects.
Transfer UV Maps
The active UV map of the selected objects will be replaced by a copy of the active UV map of the active object. If the selected object doesn’t have any UV maps, it is created. Objects must be of type mesh and must have a matching topology.
더 보기
Making Single User for unlinking data-blocks.
Next Previous
© 저작권 : This page is licensed under a CC-BY-SA 4.0 Int. License 최종 업데이트: 02/25/2021
  • Edit Page
  • Report Bug
  • 2.92
    • Loading...
  • ko
    • Loading...
