Window System Introduction
After starting Blender and closing the Splash Screen, the Blender window should look similar to the image below.
블렌더의 초기 상태 화면.
블렌더의 인터페이스는 3개의 부분으로 나눠져요:
Topbar at the very top.
Areas in the middle.
Status Bar at the bottom.
블렌더 화면의 초기 상태에요. 파란색은 Topbar, 초록색이 Area, 빨간색이 Status bar를 나타내고 있어요.
맞춤 설정
Blender also makes heavy use of keyboard shortcuts to speed up work. These can also be customized in the Keymap Editor.
테마 색깔
Blender allows for most of its interface colors to be changed to suit the needs of the user. If you find that the colors you see on screen do not match those in the Manual, it could be that your default theme has been altered. Creating a new theme or selecting/altering a pre-existing one can be done by opening the Preferences and clicking on the Themes tab.
