Double Edge Mask Node
![../../../_images/compositing_node-types_CompositorNodeDoubleEdgeMask.png](../../../_images/compositing_node-types_CompositorNodeDoubleEdgeMask.png)
Double Edge Mask Node.
The Double Edge Mask node creates a gradient between two masks.
Inputs
- Inner Mask
A mask representing the inside shape, which will be fully white.
- Outer Mask
A mask representing the outside shape, which will fade from black at its edges to white at the Inner Mask.
Properties
- Inner Edge
- All
All shapes in the Inner Mask contribute to the gradient, even ones that do not touch the Outer Mask shape.
- Adjacent Only
Only shapes in the Inner Mask that overlap with the Outer Mask contribute to the gradient.
All.
Adjacent Only.
- Buffer Edge
- Keep In
Parts of the Outer Mask that touch the edge of the image are treated as if they stop at the edge.
- Bleed Out
Parts of the Outer Mask that touch the edge of the image are extended beyond the boundary of the image.
Keep In.
Bleed Out.
Outputs
- Mask
Standard mask output.
