Realize Instances Node
Realize Instances node.
The Realize Instances node makes any instances (efficient duplicates of the same geometry) into real geometry data. This makes it possible to affect each instance individually, whereas without this node, the exact same changes are applied to every instance of the same geometry. However, performance can become much worse when the input contains many instances of complex geometry, which is a fundamental limitation when procedurally processing geometry.
Merknad
If the input contains multiple volume instances, only the first volume component is moved to the output.
Attributes
When merging attributes from multiple geometry inputs, the highest complexity data type is chosen for the output attribute. For example, if a weight attribute is a Boolean on one geometry input and a vector on another, the weight attribute on the output geometry will use the vector data type.
Named and anonymous attributes are propagated from the instance domain to the realized geometry. If an attribute exists both on the base geometry and on an instance, the attribute values from the base geometry take precedence.
Merknad
  • The id attribute receives special handling to prevent duplicate values. id values or indices of each instance are combined with id values from the geometry data points.
  • Vertex groups are preserved when realizing instances or joining geometries. If the domain and type propagation rules above result with the vertex domain and float type, then an attribute will be a vertex group on the output mesh.
Inputs
Geometry
Standard geometry input.
Selection
Which top-level instances to realize.
Realize All
Realize all levels of nested instances for each top-level instances (overrides the value of the Depth input).
Depth
Number of levels of nested instances to realize for each top-level instance.
Properties
This node has no properties.
Outputs
Geometry
Standard geometry output.
