Vector Rotate Node#
The Vector Rotate Node provides the ability to rotate a vector around a pivot point (Center).
Inputs#
- Vector
Vector to be rotated.
- Center
Point to rotate around.
- Axis (As)
Axis to rotate around.
- Angle
Angle to rotate the input vector by.
- Rotation
When Type is set to Euler, rotate the input vector by these angles around the X, Y, then Z axes in that order.
Properties#
- Type
The type of angle input.
- X/Y/Z Axis:
Rotates the vector around the defined axis and the amount of rotation is defined by the Angle input.
- Axis Angle (Rotatiehoek):
Rotates the vector around an arbitrary axis defined by the Axis input vector. The amount of rotation is defined by the Angle input.
- Euler:
Rotates the vector about a center point defined by the Center input vector. The amount of rotation on each axis is defined by the Rotation input vector.
- Invert
Inverts the rotation angle.
Outputs#
- Vector
The rotated vector.
Voorbeelden#
Vector Rotate node example.#
