Separate Components Node
../../../_images/modeling_geometry-nodes_geometry_separate-components_node.png
The Separate Components node.
The Separate Components node splits a geometry into a separate output for each type of data in the geometry.
Inputs
Geometria
Entrada padrão de geometria.
Properties
Saídas
Mesh
Componente malha da geometria de entrada.
Point Cloud
Componente point clound da geometria de entrada.
Curve
Componente curva da geometria de entrada.
Volume
Componente volume da geometria de entrada.
Instances
Instances component of the input geometry. Even if the instances contain geometry data with one of the other types, all instances will be added to this output. A Realize Instances Node can be added to move the data from geometry instances to their corresponding outputs.
