Set ID Node
Set ID node.
The Set ID node fills the id attribute on the input geometry. If the attribute does not
exist yet, it will be created with a default value of zero. The ID is also created by
the Distribute Points on Faces, and it is used in
the Random Value Node and other nodes if it exists.
The input node for this data is the ID Node.
Inputs
- Geometria
Entrada padrão de geometria.
- Seleção
Whether or not to change the value on each point or instance. True values mean the value will be changed, false values mean the value will remain the same.
- Identificador
The value for each element. By default, this input uses the index, which is useful when stable IDs are desired when deleting a dynamic number of instances.
Properties
Saídas
- Geometria
Saída padrão de geometria.
