Mesh Boolean Node
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
The Mesh Boolean node.
Inputs
- Mesh 1/2
Entrada padrão de geometria.
- Self Intersection
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
- Hole Tolerant
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
Properties
- Operação
- Intersecção
Produz uma nova geometria contendo apenas o volume dentro de tanto a geometria 1 e geometria 2.
- União
The two input meshes are joined, then any interior elements are removed.
- Diferença
Geometria 2 é subtraída da geometria 1 (tudo fora da geometria 2 é mantido).
Saída
- Mesh
Saída padrão de geometria.
