Domain Size Node
The Domain Size outputs the size of an attribute domain on the selected geometry type, for example, the number of edges in a mesh, or the number of points in a point cloud.
For more information about attribute domains, see the geometry attributes page.
Inputs
- Geometria
Entrada padrão de geometria.
Propriedades
- Component
Which geometry type to retrieve the domain sizes from.
Saídas
- Point Count
The size of the Point domain on any supported geometry.
- Edge Count
The size of the Edge domain on meshes.
- Face Count
The size of the Face domain on meshes.
- Face Corner Count
The size of the Face Corner domain on meshes.
- Spline Count
The size of the Spline domain on curves.
- Instance Count
The number of top-level instances in the geometry. Nested instances are not considered.
