Track Position Node¶
Track Position Node.¶
The Track Position node is used to return information about a tracking marker to the Compositor.
Inputs¶
This node as no inputs.
Properties¶
- Movie Clip
Used to select a Movie Clip data-block to use, for controls see Меню блока данных.
- Tracking Object
Camera object to get track information from.
- Track Name
The name of the track to get track information from.
- Position
Which marker position to use for output.
- Absolute
Outputs an absolute position of a marker.
- Relative Start
Outputs the positions of a marker relative to the first marker of a track.
- Relative Frame
Outputs the positions of a marker relative to the markers of the given Frame.
- Absolute Frame
Outputs the absolute positions of a marker at the given Frame.
Outputs¶
- X/Y
The marker’s X and Y location.
- Speed
The velocity of the marker, measured in pixels per frame. This could be used to fake effects like motion blur by connecting it to the Vector Blur Node.
