Attribute Color Ramp¶
Maps values from a float attribute to their corresponding color, based on a color ramp. The resulting colors are stored on the geometry in a color attribute.
Inputs¶
- Geometry
Standard geometry input.
- Attribute
Name of the attribute that is used as input. It should be a float attribute with values between zero and one.
- Result
Name of the attribute where the output is stored. If the attribute does not exist yet, it is created.
Properties¶
- Color Ramp
For controls see Віджет Градієнта Кольорів – Color Ramp Widget.
Outputs¶
- Geometry
Standard geometry output.
