Edge Split¶
The Edge Split Node.¶
Like the Модифікатор «Розділ Ребром» – Edge Split Modifier, the Edge Split node splits and duplicates edges within a mesh, breaking „links“ between faces around those split edges.
Примітка
Splitting edges effectively breaks the mesh topology.
Inputs¶
- Geometry
Standard geometry input.
- Edge Angle
When enabled, edges will be split if the angle between its two adjacent faces is greater than the Split Angle.
- Angle
On 0: all edges are split. On 180: no edges are split.
- Sharp Edges
When enabled, edges will be split if they were marked as sharp.
Properties¶
This node has no properties.
Outputs¶
- Geometry
Standard geometry output.
