Вступ щодо Системи Вікон – Window System Introduction
After starting Blender and closing the Splash Screen, the Blender window should look similar to the image below.
Стандартне вікно при запуску Blender’а.
Інтерфейс Blender’а поділяється на три головні частини:
Topbar – Верхньосмуга на самому верху.
Areas – Області посередині.
Status Bar – Смуга Статусу внизу.
Blender’s default Screen Layout. Topbar (blue), Areas (green) and Status Bar (red).
Customization – Кастомізація
Blender also makes heavy use of keyboard shortcuts to speed up work. These can also be customized in the Keymap Editor.
Теми кольорів – Theme colors
Blender allows for most of its interface colors to be changed to suit the needs of the user. If you find that the colors you see on screen do not match those in the Manual, it could be that your default theme has been altered. Creating a new theme or selecting/altering a pre-existing one can be done by opening the Preferences and clicking on the Themes tab.
