Translate Instances Node
The Translate Instances node moves top-level geometry instances in local or global space.
The Примірники page contains more information about geometry instances.
Inputs – Уводи
- Geometry – Геометрія
Standard geometry input.
- Selection – Вибрання
Boolean field used to determine if an instance will be translated.
- Translation – Переклад
The vector to translate the instances by.
- Local Space – Локальний Простір
If enabled, the instances are translated relative to their initial rotation. Otherwise they are translated in the local space of the modifier object.
Properties – Властивості
Outputs – Виводи
Standard geometry output.
