Boolean Math Node
The Boolean Math node performs a basic logical operation on its inputs.
Inputs – Уводи
- Boolean – Булів
Two standard Boolean inputs.
Properties – Властивості
- Mode – Режим
- AND
True when both inputs are true. (AND)
- OR
True when at least one input is true. (OR)
- NOT
Opposite of the input. (NOT)
- NAND
(True when at least one input is false. NAND)
- NOR
True when both inputs are false. (NOR)
- EQV
True when both inputs are equal. Also known as «exclusive nor». (XNOR)
- NEQV
(XOR) True when both inputs are different. Also known as «exclusive or».
- IMPLY
True unless the first input is true and the second is false. (IMPLY)
- NIMPLY
True when the first input is true and the second is false. Also known as «»not imply». (NIMPLY)
Вивід – Output
- Boolean – Булів
Standard Boolean output.
