Field at Index Node
The Field at Index node allows accessing data of other elements in the context geometry. It is similar to the Transfer Attribute Node in Index mode. The main difference is that this node does not require a geometry input, because the geometry from the field context is used.
Inputs – Уводи
- Index – Індекс
The index of the element in the selected domain to retrieve data from, i.e. «the fourth face», or «the first control point».
- Value – Значення
The field to retrieve data from.
Properties – Властивості
- Домен – Domain
The attribute domain used for for evaluation of the Value input. This is useful because it can be a different domain than the domain from the field context, i.e. to choose a vertex for each face.
Вивід – Output
- Value – Значення
The value of the input field at the given index.
