Face is Planar Node
Face is Planar Node.
The Face is Planar node outputs whether every triangle of a quads or N-gons is on the same plane as all of the others, in other words, if they have the same normal.
For example, a non-planar face can be created by moving a single vertex in a face but not the others. Triangles will always be planar.
输入
阈值
The distance a point can be from the surface before the face is no longer considered planar.
属性
这个节点没有属性。
输出
平面
Whether each mesh face is planar.
示例
../../../_images/modeling_geometry-nodes_input_face-is-planar_simple.png
Combined with the Set Material Node, this node is used to visualize all non-planar faces in a mesh.
