Set Shade Smooth Node
Set Shade Smooth node.
The Set Shade Smooth node controls whether the mesh's faces look smooth in the viewport and renders. The input node for this data is the Is Shade Smooth node.
输入
网格
Standard geometry input.
平滑着色
When true, the selected faces will be marked to render smooth shaded. Otherwise the faces will be rendered flat shaded.
选择
Boolean input for selecting which faces will have the Shade Smooth value applied.
属性
这个节点没有属性。
输出
网格
Standard geometry output.
