Object Info Node
![../../../_images/render_shader-nodes_input_object-info_node.png](../../../_images/render_shader-nodes_input_object-info_node.png)
Object Info Node.
The Object Info node gives information about the object instance. This can be useful to give some variation to a single material assigned to multiple instances, either manually controlled through the object index, based on the object location, or randomized for each instance. For example a Noise texture can give random colors or a Color Ramp can give a range of colors to be randomly picked from.
Inputs
This node has no inputs.
Eigenschaften
This node has no properties.
Outputs
- Speicherort
Location of the object in world space.
- Color
Object color, same as Color in the
.- Object Index
Object pass index, same as Pass Index in the
.- Material Index
Material pass index, same as Pass Index in the
.- Random
Random number unique to a single object instance.
Bemerkung
Note that this node only works for material shading nodes; it does nothing for light and world shading nodes.
Example
![../../../_images/render_shader-nodes_input_object-info_example.png](../../../_images/render_shader-nodes_input_object-info_example.png)
![../../../_images/render_cycles_render-settings_motion-blur_example-cubes.jpg](../../../_images/render_cycles_render-settings_motion-blur_example-cubes.jpg)
