Separate Components Node#
Separate Components node.
The Separate Components node splits a geometry into a separate output for each type of data in the geometry.
Inputs#
Geometry
Standard geometry input.
Eigenschaften#
This node has no properties.
Outputs#
Mesh
Mesh component of the input geometry.
Kurve
Curve component of the input geometry.
Point Cloud
Point cloud component of the input geometry.
Volume
Volume component of the input geometry.
Instances
Instances component of the input geometry. Even if the instances contain geometry data with one of the other types, all instances will be added to this output. A Realize Instances Node can be added to move the data from geometry instances to their corresponding outputs.
