Store Named Attribute Node¶
The Store Named Attribute node stores the result of a field on a geometry as an attribute with the specified name. If the attribute already exists, the data type and domain will be updated to the values chosen in the node. However, keep in mind that the domain and data type of Built-In Attributes cannot be changed.
Compared with the Capture Attribute Node, this node basically does the same thing, but the attribute gets a name instead of an anonymous reference. For reusing the data in the same node tree, the Capture Attribute node might be preferable since it does not create the chance for name conflicts in the input geometry.
Bemerkung
If the input geometry contains multiple geometry component types, the attribute will be created on each component that has the chosen domain.
Inputs¶
- Geometry
Standard geometry input.
- Selection
A boolean field input for each element indicating whether to store the attribute value for the given index. If the attribute does not exist, unselected parts are filled with zero values; otherwise, only the selected parts are filled.
- Wert
The input field to evaluate.
- Name
The name to give the stored data.
Eigenschaften¶
- Data Type
- Domain
Which attribute domain to store the evaluated data on.
Outputs¶
- Geometry
Standard geometry output.
