Convex Hull Node¶
The Convex Hull node outputs a convex mesh that is enclosing all points in the input geometry.
Bemerkung
When the node is used on a geometry with instances, the algorithm will run once per instance, resulting in many convex hull meshes in the instance geometries. The Realize Instances node can be used to get a convex hull of an entire geometry.
Wichtig
Volumes are not supported by this node, and attributes are not automatically transferred to the result.
Inputs¶
- Geometry
Standard geometry input.
Eigenschaften¶
This node has no properties.
Outputs¶
- Convex Hull
Mesh that encloses all points in the input.
