Render Layers Node
Render Layers Node.
This node is the starting place for getting a picture of your scene into the compositing node tree.
Entradas
This node has no input sockets.
Propiedades
- Scene
Select the scene within your blend-file. The scene information taken is the raw footage (pre-compositing and pre-sequencing).
Consejo
To use composited footage from another scene, it has to be rendered into a multi-layer frameset (e.g.
OpenEXR) as an intermediate file store and then imported with Image input node again.- Render Layer
A list of available Render Layers. The render button is a shorthand to re-render the active scene.
Salidas
- Imagen
Imagen renderizada.
- Alfa
Canal Alfa.
Render Passes Sockets
Depending on the Render passes that are enabled, other sockets are available. See render passes.
