Hair Info Node
../../../_images/render_shader-nodes_input_hair-info_node.png
Hair Info Node.
The Hair Info node gives access to Hair information.
Ingressi
Proprietà
This node has no properties.
Uscite
Is Strand
Outputs 1 when the shader is acting on a strand, otherwise 0.
Intercept
The point along the strand where the ray hits the strand (1 at the tip and 0 at the root).
Length
The total measurement from the root to the tip of the strand, interpreted as a grayscale value from 0 to infinity.
Spessore
The thickness of the strand at the point where the ray hits the strand.
Tangent Normal
Tangent normal of the strand.
Casuale
A random per-hair value in the range from 0 to 1. It can for example be used in combination with a color ramp, to randomize the hair color.
