Object Info Node
The Object Info node gives information about the object instance. This can be useful to give some variation to a single material assigned to multiple instances, either manually controlled through the object index, based on the object location, or randomized for each instance. For example a Noise texture can give random colors or a Color Ramp can give a range of colors to be randomly picked from.
Ingressi
Proprietà
This node has no properties.
Uscite
- Posizione
Location of the object in world space.
- Colore
Object color, same as Color in the
.- Object Index
Object pass index, same as Pass Index in the
.- Material Index
Material pass index, same as Pass Index in the
.- Casuale
Random number unique to a single object instance.
Nota
Note that this node only works for material shading nodes; it does nothing for light and world shading nodes.
