Separate Components Node
![Separate Components node.](../../../_images/node-types_GeometryNodeSeparateComponents.webp)
The Separate Components node splits a geometry into a separate output for each type of data in the geometry.
Ingressi
- Geometria
Standard geometry input.
Proprietà
This node has no properties.
Uscite
- Mesh
Mesh component of the input geometry.
- Point Cloud
Point cloud component of the input geometry.
- Curva
Curve component of the input geometry.
- Volume
Volume component of the input geometry.
- Instances
Instances component of the input geometry. Even if the instances contain geometry data with one of the other types, all instances will be added to this output. A Realize Instances Node can be added to move the data from geometry instances to their corresponding outputs.
