Boolean Math Node
Boolean Math Node.
The Boolean Math node performs a basic logical operation on its inputs.
Ingressi
Boolean
Two standard Boolean inputs.
Proprietà
Modalità
AND
True when both inputs are true. (AND)
OR
True when at least one input is true. (OR)
NOT
Opposite of the input. (NOT)
NAND
(True when at least one input is false. NAND)
NOR
True when both inputs are false. (NOR)
EQV
True when both inputs are equal. Also known as «exclusive nor». (XNOR)
NEQV
(XOR) True when both inputs are different. Also known as «exclusive or».
IMPLY
True unless the first input is true and the second is false. (IMPLY)
NIMPLY
True when the first input is true and the second is false. Also known as «»not imply». (NIMPLY)
Output
Boolean
Standard Boolean output.
