Rotate Euler Node
The Rotate Euler node rotates an Euler rotation.
Ingressi
- Rotazione
The Euler rotation to rotate.
- Rotate By
Specifies how much an Euler rotation is rotated. This input is only available when the rotation type is set to Euler.
- Asse
The axis to rotate around. This input is only available when the rotation type is set to Axis Angle.
- Angolo
The angle to rotate by around the specified axis. This input is only available when the rotation type is set to Axis Angle.
Proprietà
- Rotation Type
- Axis Angle
Use separate axis and angle inputs to control the rotation.
- Euler
Use an Euler input to control the rotation.
- Space
- Oggetto
Rotate an Euler rotation in the evaluated object’s space.
- Locale
Rotate an Euler rotation in local space.
Uscite
- Rotazione
The rotated Euler rotation.
