Introduzione
Blender contains different node-based editors with different purposes, so this section only explains how to work with nodes in general. The list below shows the different types of nodes and where they’re documented.
../../../_images/interface_controls_nodes_introduction_example.jpg
Esempio di un editor di nodi.
Icona
Nome
Descrizione
../../../_images/interface_controls_nodes_introduction_icons-geometry.png
Used for procedural modeling.
../../../_images/interface_controls_nodes_introduction_icons-material.png
Shader Nodes
Used to create materials for objects.
../../../_images/interface_controls_nodes_introduction_icons-render-layers.png
Composite Nodes
Used to edit rendered images.
../../../_images/interface_controls_nodes_introduction_icons-texture.png
Texture Nodes
Used to create custom textures.
Interfaccia Editor
Barra degli strumenti
La Barra degli strumenti contiene un set di strumenti che possono essere utilizzati nell’editor dei nodi.
Aggiunta di nodi
Riferimento
Menù:
Aggiungi
Scorciatoia:
Shift-A
Nodes are added via the Add menu in the editor’s header or using a keyboard shortcut.
Nodes can also be added by dragging a connection from an existing node’s input or output socket and dropping the connection above an empty space instead of connecting to another socket. This action will open a search menu with a list of compatible nodes and their sockets that can be added and connected to the existing node. Confirming the menu selection will add the node which can then be moved and placed.
