Particle Info Node
Cycles Only
Particle Info Node.
The Particle Info node can be used in the material node tree for objects that are used as the instancing objects, when you use Object or Collection Render mode of a particle system.
This node gives access to the data of the particle that spawned the object instance. It can be useful to give some variation to a single material assigned to multiple instances of instancing object.
Nota
This node currently only supports parent particles. Info from child particles is not available.
Ingressi
Proprietà
This node has no properties.
Uscite
Index
Index number of the particle (from 0 to number of particles).
Casuale
A random per-particle value in the range from 0 to 1. It can for example be used in combination with a color ramp, to randomize the particle color.
Age
Age of the particle in frames.
Lifetime
Total lifespan of the particle in frames.
Posizione
Location of the particle.
Dimensione
Size of the particle.
Velocity
Velocity of the particle.
Angular Velocity
Angular velocity of the particle.
