Convex Hull Node
../../../_images/modeling_geometry-nodes_geometry_convex-hull_node.png
Nó Convex Hull.
O nó Convex Hull gera a saída de uma malha convexa que envolve todos pontos na geometria de entrada.
Nota
When the node is used on a geometry with instances, the algorithm will run once per instance, resulting in many convex hull meshes in the instance geometries. The Realize Instances node can be used to get a convex hull of an entire geometry.
Importante
Volumes are not supported by this node, and attributes are not automatically transferred to the result.
Inputs
Geometria
Entradas de geometria padrão.
Properties
Esse nó não tem propriedades.
Saídas
Convex Hull
Malha que envolve todos pontos da entrada.
