Separate Components Node
Nó Separate Components.
The Separate Components node splits a geometry into a separate output for each type of data in the geometry.
Inputs
- Geometria
Entrada padrão de geometria.
Properties
Saídas
- Mesh
Componente malha da geometria de entrada.
- Point Cloud
Componente point clound da geometria de entrada.
- Curve
Componente curva da geometria de entrada.
- Volume
Componente volume da geometria de entrada.
- Instances
Instances component of the input geometry. Even if the instances contain geometry data with one of the other types, all instances will be added to this output. A Realize Instances Node can be added to move the data from geometry instances to their corresponding outputs.
