Instances to Points Node
../../../_images/modeling_geometry-nodes_point_instances-to-points_node.png
The Instances to Points node.
The Instances to Points node generates points on origins of top-level instances.
Nota
Top-level instances are those that are owned by the node’s input geometry. Instances owned by other instances, i.e. nested instances, are not considered by this node.
Inputs
Instances
Entrada padrão de geometria.
Seleção
The instances used to generate points. True values mean a point is created for the instance, false values mean the instance is skipped.
Posição
Overrides the default position of generated point.
Raio
Controls the radius of the result points.
Properties
Saídas
Pontos
Saída padrão de geometria.
