Rotate Instances Node
../../../_images/modeling_geometry-nodes_instances_rotate-instances_node.png
The Rotate Instances node.
The Rotate Instances node rotates geometry instances in local or global space.
The Instances page contains more information about geometry instances.
Inputs
Geometria
Entrada padrão de geometria.
Seleção
Boolean field used to determine if an instance will be rotated.
Rotação
The Euler rotation to rotate the instances by.
Pivot Point
The position around which each instance is rotated. If the Local Space input is true, the location is relative to the initial transform of the instance.
Local Space
If enabled, the instances are rotated in local space. In other words, they are rotated around the axes described by the initial transform of each instance. When the input is disabled, the pivot point and rotation are specified in the local space of the modifier object.
Properties
Saídas
Geometria
Saída padrão de geometria.
