Object Info Node
../../../_images/render_shader-nodes_input_object-info_node.png
Nó Object Info.
The Object Info node gives information about the object instance. This can be useful to give some variation to a single material assigned to multiple instances, either manually controlled through the object index, based on the object location, or randomized for each instance. For example a Noise texture can give random colors or a Color Ramp can give a range of colors to be randomly picked from.
Inputs
Este nó não possui conectores de entrada.
Properties
Saídas
Localização
Localização do objeto no world space.
Color
Object color, same as Color in the Properties ‣ Object Properties ‣ Viewport Display.
Índice de objeto
Object pass index, same as Pass Index in the Properties ‣ Object Properties ‣ Relations.
Material Index
Material pass index, same as Pass Index in the Properties ‣ Material ‣ Settings.
Random
Random number unique to a single object instance.
Nota
Note that this node only works for material shading nodes; it does nothing for light and world shading nodes.
Exemplo
../../../_images/render_shader-nodes_input_object-info_example.png
../../../_images/render_cycles_render-settings_motion-blur_example-cubes.jpg
Example blend-file.
