Point Info
Cycles Only
../../../_images/render_shader-nodes_input_point-info_node.png
Point Info Node.
The Point Info node can be used in the material node tree for point cloud objects and gives access to the data of individual points. It can be useful to give some variation to a single material assigned a point cloud object.
Inputs
Este nó não possui conectores de entrada.
Properties
Saídas
Localização
Localização das partículas.
Raio
Tamanho das partículas.
Random
A random per-point value in the range from 0 to 1. It can for example be used in combination with a color ramp, to randomize the point color.
