Particle Info Node
Cycles Only
Particle Info Node.
The Particle Info node can be used in the material node tree for objects that are used as the instancing objects, when you use Object or Group Render mode of a particle system.
This node gives access to the data of the particle that spawned the object instance. It can be useful to give some variation to a single material assigned to multiple instances of instancing object.
Nota
This node currently only supports parent particles. Info from child particles is not available.
Inputs
Este nó não possui conectores de entrada.
Properties
Saídas
- Índice
Index number of the particle (from 0 to number of particles).
- Random
A random per-particle value in the range from 0 to 1. It can for example be used in combination with a color ramp, to randomize the particle color.
- Idade
Age of the particle in frames.
- Tempo de vida
Total lifespan of the particle in frames.
- Localização
Localização das partículas.
- Tamanho
Tamanho das partículas.
- Velocidade
Velocidade das partículas.
- Velocidade angular
Velocidade angular das partículas.
