Realize Instances Node
The Realize Instances node makes any instances (efficient duplicates of the same geometry) into real geometry data. This makes it possible to affect each instance individually, whereas without this node, the exact same changes are applied to every instance of the same geometry. However, performance can become much worse when the input contains many instances of complex geometry, which is a fundamental limitation when procedurally processing geometry.
Nota
If the input contains multiple volume instances, only the first volume component is moved to the output.
Atributos
When merging attributes from multiple geometry inputs, the highest complexity data type is chosen
for the output attribute. In other words, if a weight
attribute has a Boolean type on one geometry input
and a vector data type on another geometry, the weight
attribute on the output geometry will have
a vector data type.
Named and anonymous attributes are propagated from the instance domain to the realized geometry. If the same attribute exists on the geometry and on an instance, the attribute values from the geometry has precedence over the values on the instances.
In order to avoid creating duplicate values, the id
attribute has special handling.
The id
values or indices of each instance are combined with id values from the points on
geometry data.
Aviso
Like other geometry nodes, this node always outputs generic typed attributes. So instead of a Vertex Group attribute, it will create a «Float» attribute on the result, and it will create a generic 2D vector attribute instead of a special «UV Map» attribute. Some other areas of Blender don’t properly handle generic attributes in version 3.0.
Custom face corner normals are also not transferred currently.
Inputs
- Geometria
Entrada padrão de geometria.
Propriedades
Saídas
- Geometria
Saída padrão de geometria.
