Instance Rotation Node
The Instance Rotation outputs the XYZ Euler rotation of each top-level instance in the local space of the modifier object.
The Instances page contains more information about geometry instances.
Nota
Though rotations are often displayed in units of degrees in the spreadsheet or node editor, they are stored internally in radians, so this node outputs radians.
Inputs
Este nó não possui conectores de entrada.
Properties
Saídas
- Rotação
Vector that indicates the rotation of each top-level instance in radians.
