Separate Components Node
The Separate Components node.
The Separate Components node splits a geometry into a separate output for each type of data in the geometry.
Inputs – Уводи
- Geometry – Геометрія
Standard geometry input.
Properties – Властивості
Outputs – Виводи
- Mesh – Сіть
Mesh component of the input geometry.
- Point Cloud
Point cloud component of the input geometry.
- Curve – Крива
Curve component of the input geometry.
- Volume – Об’єм
Volume component of the input geometry.
- Примірники
Instances component of the input geometry. Even if the instances contain geometry data with one of the other types, all instances will be added to this output. A Realize Instances Node can be added to move the data from geometry instances to their corresponding outputs.
