Subdivision Surface Node
../../../_images/modeling_geometry-nodes_mesh_subdivision-surface_node.png
The Subdivision Surface Node.
The Subdivision Surface node adds new faces to mesh geometry using a Catmull-Clark subdivision method.
Inputs – Уводи
Mesh – Сіть
Standard geometry input.
Level – Рівень
The number of subdivisions to apply to the input geometry.
Crease – Складка
Controls how smooth edges should be with Виважені Складки на Ребрах – Weighted Edge Creases.
Properties – Властивості
Згладження UV – UV Smooth
Controls how subdivision smoothing is applied to UVs.
None – Нема
UVs remain unchanged.
Keep Corners
UV islands are smoothed, but their boundary remain unchanged.
Keep Corners, Junctions
UVs are smoothed, corners on discontinuous boundary and junctions of three or more regions are kept sharp.
Keep Corners, Junctions, Concave
UVs are smoothed, corners on discontinuous boundary, junctions of three or more regions and darts and concave corners are kept sharp.
Keep Boundaries
UVs are smoothed, boundaries are kept sharp.
All – Усе
UVs and their boundaries are smoothed.
Boundary Smooth
Controls how open boundaries (and corners) are smoothed.
All – Усе
Smooth boundaries, including corners.
Keep Corners
Smooth boundaries, but corners are kept sharp.
Outputs – Виводи
Mesh – Сіть
Standard geometry output.
